Re: Multimeters
Posted by Janicholson on December 14, 2005 at 06:48:14 from (199.17.6.175):
In Reply to: Re: Multimeters posted by BobOHIO on December 14, 2005 at 06:30:41:
Seasons greetings and solutions (of various types)
I believe two things are important to consider.
A digital multimeter is a very fine choice for some things:
1) Home wireing 110-220 and electronics
2) Battery voltage and direct current applications
3) ohms/resistance testing
I like Simpson, Fluke, Craftsman, Snap-On/Bluepoint
A digital meter has one (very important) failure. They do a very poor job of measuring intermittent (chopped) DC sources. They sample voltage and current using a sample rate that is so instantaneous that the display jumps all around the actual value. This often leads to the assumption of problems that are not there.
An inexpensive Analog Meter with an actual needle that moves on a scale (especially when adjusted or compared to the nice digital unit on a stable source of volts) will average the pulses and give usable information better.
The reason for the importance to us (YT types) is because the voltage regulators and cutout relays, and un-suppressed electrical systems on all older generator based equipment is manufactured to chop up voltage to control rates of charge and the output of DC in the armature/commutator/brushes.
Do both and be happy.
Jim (vast experience on this issue) Nicholson
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
