Re: Multimeters
Posted by rumplestiltskin on December 14, 2005 at 07:14:25 from (65.216.75.240):
In Reply to: Re: Multimeters posted by Janicholson on December 14, 2005 at 06:48:14:
I currently (no pun intended) have three multimeters. Two are cheap ($10 - $20) analogs and one is a more expensive digital.
I almost never use the digital. The analogs give much faster readings, and are better at showing any fluctuations in the signal. Also, if an analog meter falls victim to some danger (dropped, stepped on, fried, fan blade, etc) I can replace it dirt cheap. I'm usually just checking resistance, continuity, and presence of voltage (don't usually care how much).
If you have some aversion to anlog meters, get a digital. But my choice, if I had ONE multimeter, would be analog.
Oh, yeah, one other thing: Most analogs will not run down their batteries in you leave them on. Digitals will -- and the batteries are often oddball (i.e., expensive and hard to find). Whatever kind of meter you buy, try to get one that uses standard (AA, AAA, etc) batteries.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
