Re: Hyd Leak on Cub
Posted by Bigdog on December 14, 2005 at 13:08:28 from (65.24.70.69):
In Reply to: Hyd Leak on Cub posted by Florida Tom on December 14, 2005 at 12:14:56:
There is a bottom plate and gasket on the touch control unit. You may either have broken bolts or a bad gasket. Worst case - a cracked reservoir. Gaskets and rebuild kits are available from Case IH. Get the number from the side of the unit as there are a couple of them.
