Re: B parts on a SA
Posted by gene bender on December 15, 2005 at 03:14:17 from (66.43.221.81):
In Reply to: B parts on a SA posted by bjk on December 14, 2005 at 16:48:19:
Grille can be cut to fit around steering sector. Final drive parts will interchange but not the housings as the drawbars mount with different stuff. Depending on which parts you need mite not be too good of a deal unless you could sell the B stuff when you are done.
