Re: H Starter short circuit
Posted by captaink on December 15, 2005 at 10:10:14 from (66.115.214.56):
In Reply to: Re: H Starter short circuit posted by Rock2k on December 15, 2005 at 09:49:38:
To fix that connection I find it is easiest to do a good job if you take out the field block mounting screws from the outside of the case and take out the field coils and the terminal post. This will allow you to use a “heat sink” to protect the insulation on the coils, and get both the field coil lead and the post clean and hot enough to get the solder to hold good.
Glad I could be of help. Good luck with your starter.
