Re: F-20 oil bath air filter
Posted by RN on December 15, 2005 at 22:46:30 from (166.126.218.219):
In Reply to: F-20 oil bath air filter posted by Indiana Mike on December 15, 2005 at 22:33:19:
F20 aircleaner oil? 30wt summer, could use 10-30 winter, basicly use same as engine oil. Clean the screen good, you should disassemble to get out old mud, hope you don't get a 1/2 coffe can full like I did. Mag? point set .013-.015, mag safety gap is supposed to be about 1/4 inch, lever movement reduces to less than point gap- grounds out to shut off, 2 ground position not right. Check lever linkage, does mag mount end set outward from engine? Check manual if you have one, get a manual if you don't. I got mine from Rice equipment out of Pennsylvania. RN
