Re: BN clutch questi ons
Posted by Red Dave on December 16, 2005 at 15:06:14 from (66.109.236.130):
In Reply to: BN clutch questi ons posted by Bill in MI on December 16, 2005 at 14:09:11:
I don't know if the worn pilot bearing could do that, but I would certainly fix it while it's apart.
A clutch that has grease or oil on it will grab. Does the disc or pressure plate have a glaze on them? Did you make sure it is clean?
I usually clean the the disc (both sides), the pressure plate & the flywheel with Brake cleaner. You can get it at any auto parts store. You may also need to get the flywheel ground to spec.
Maybe it's time for a new disc and pressure plate too.
