Re: Will a Model 31 Loader fit on a 400?
Posted by RustyFarmall on December 17, 2005 at 14:35:22 from (207.32.13.247):
In Reply to: Will a Model 31 Loader fit on a 400? posted by Troy (MI) on December 17, 2005 at 13:35:10:
Yes, it will work, but you will have to fabricate a 4 inch spacer to fit between the axle on the 400 and the loader mount. That spacer is an IH item but I don't know the part number. Years ago when my dad traded his M for a brand new 350 the dealer came up with the spacers so the #31 loader could be used on the longer 350.
