Re: Farmall Super H Gets stuck in Gear
Posted by Hugh MacKay on December 18, 2005 at 08:45:20 from (209.226.247.40):
In Reply to: Farmall Super H Gets stuck in Gear posted by J. Spring on December 18, 2005 at 05:39:59:
J Spring: Tom has it right, worn shift lever. Have the welder build so it nicely fills one notch on those shift rails. Then grind until it shifts smoothly. It should be close to a perfect rectangle, very slightly rounded on corners.
