Re: Differential Pinion Gear Adjustment
Posted by the tractor vet on December 18, 2005 at 19:45:21 from (4.124.82.168):
In Reply to: Differential Pinion Gear Adjustment posted by Roger46 on December 18, 2005 at 19:23:17:
If i have to switch cases i try and get one from one of my friends and get the shims that came out of it if i can and if not then ya got to start from begining and i get a shim kit and start micen and doing the set up Some red lead or white lead helps myself i like the red as i can see the pattern better the it is just a matter of getting the backlash set and yes you will have it apart several times . A mic and a depth mic and a dial indicator is a must have .
