Re: 686 IH opinions needed
Posted by Mapleridge on December 19, 2005 at 18:53:45 from (24.198.52.183):
In Reply to: 686 IH opinions needed posted by M Nut on December 19, 2005 at 10:06:41:
I have run a 686 with a d312 non hydro for the last 10 years and it is a great tractor. We have 3 JDs and 2 IHs and this is my father's favorite. Good power, smooth engine, nice operators station, good hydraulics. I do think $10,000 is a bit high unless you know the condition of more than the engine and ta. Make sure the hydraulics are in good shape by hooking both the remotes and the three point hitch to something. When working properly, they are quick and powerfull. Make sure the ta or shift handle doesn't hit the metal guards in any gear (it is adjustable). Connect to a PTO attachment. The PTO should engage smoothly. It is about the best control lever on a tractor I have found. Check the brakes. They are dry disks and have a tendancy to grab when cold and need to be adjusted periodically. The can work very good, or they can work very bad depending on condition. Other things to look for that I have had to fix: tie rod ends, slop in the front axle supports, slop in the rear axle clamps (drive down the road and make sure the rear tires are spinning true), slop in the Draw bar supports (draw bar has a raised support in front making it rock a bit more than a straight one), check the clutch by riding it a bit. It shouldn't surge. Overall it is a great tractor and cheap parts are readilly available but is at 30 years old.
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
