Re: carburetor problem
Posted by Dellbertt on December 21, 2005 at 14:41:54 from (204.39.210.155):
In Reply to: carburetor problem posted by philippe D (france) on December 21, 2005 at 14:14:22:
I am not an expert but it seems to me you have to check ANY place that it could be sucking air. Like between carb and manifold, manifold and head. could be a crack in the manifold. Also the idle adjustment, the float adjustment. Valve adjustment. Did you take the gas line off and make sure it is running from tank properly. You may have junk in the gas. Do you have a screen on the top of the sediment bowl. You will get lots of advice better than mine. good luck
