Re: Farmall H carb. still leaks
Posted by John in Ct on December 21, 2005 at 18:30:25 from (69.24.45.49):
In Reply to: Re: Farmall H carb. still leaks posted by riverbend on December 21, 2005 at 15:47:26:
Thanks for replying. My origional carb ( which didn't run well) was also leaking at the metering nozzel clamp nut. I tightened it up and broke it. I decided to buy a "rebuilt" carb. to solve all of my problems (came with a cracked float, sand in it, too long of a plug that was cutting off all fuel at low idle, etc.). My old carb would never run below 550 rpm's. Was told on this site to replace the throttle shaft bushing. I decided to redo my "rebuilt" carb. New throttle shaft bushing ( reamed to size), nos throttle plate, new choke shaft, IH kit. It runs great( can get it down to 450 rpms) except leaks at the metering nozzle clamp nut.I tightened the nut pretty tight but don't want to break the metering nozzle. I will try 2 washers. It is possible I have a cracked bowl but what are the odds of 2 cracked bowls? Heehee. With my luck probably very high.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
