Re: Farmall H carb. still leaks
Posted by riverbend on December 21, 2005 at 15:47:26 from (208.160.34.204):
In Reply to: Farmall H carb. still leaks posted by John in CT on December 20, 2005 at 18:29:17:
You can't use a copper washer. The metering nozzle will break before it seals. The fibre washers should be plenty for sealing the nut (it works for most of the rest of us...). I think that the fibre washers are more forgiving than even an annealed copper washer.
Do you have a small washer under the hex on the nozzle ? Did this carb leak at the nut before you rebuilt it ? When you rebuilt the carb, did you replace the metering nozzle ? If you still have the old one, clean it up and put it back in. Tighten it until it stops leaking or it breaks.
What happens if you try two washers under the nut ?
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
