Re: 1466 another question
Posted by Weldon on December 21, 2005 at 19:08:47 from (71.28.65.125):
In Reply to: Re: 1466 another question posted by SGT K on December 21, 2005 at 05:30:50:
In the photo you entitled "Gear Teeth in the transmission" the piece near the left side of the photo is a part of a detent roller not a gear tooth. Without the detent roller, shift linkage feels loose and does not " snap " when going into or coming out of High, Low and Reverse. Not difficult to replace the roller. The photo is not quite clear enough to identify the other two pieces . ( However I think that they are the other pieces of the detent roller). If you have a pronounced "click" when you are in reverse, then they are teeth off the reverse gear where the park lock pawl has chipped them off.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
