Re: Farmall H carb. still leaks
Posted by John in CT on December 22, 2005 at 08:27:16 from (69.24.45.46):
In Reply to: Re: Farmall H carb. still leaks posted by riverbend on December 21, 2005 at 19:47:36:
24693D idle outlet plug. It is an easy check to see if yours is too long. Does it idle ok 450 rpm's? If no, take carb apart. Take idle outlet plug out. Flip carb over, hold finger over idle outlet plug hole and spray carb cleaner through the little hole on the bottom of the top half of the carb. It should come out in the slit near the butterfly. If it does, put plug back in. Spray again and it should come out in the same place. If not, it is too long.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
