Re: Belt Pulley Unit
Posted by Slappy on December 22, 2005 at 13:56:02 from (70.149.247.171):
In Reply to: Belt Pulley Unit posted by billOH on December 20, 2005 at 15:34:19:
If it is like the pulley on the Model H, it just drops right inand bolts down (use a gasket of course). There is a rod (3/8" I think) that runs from the pulley control arm to the plate on the steering shaft that controls starts and stops the pulley (i.e., it dosent runn off the PTO). If you can"t find a rod, you can make one easy enough.
