Re: Can I use Hi-Tac to seal my carb ?
Posted by Janicholson on December 22, 2005 at 18:38:12 from (66.173.50.67):
In Reply to: Can I use Hi-Tac to seal my carb ? posted by John in Ct on December 22, 2005 at 18:26:46:
Fuels now contain alcohol which can disolve some sealants (I think Hi-Tac) is affected over time. Depending on the leak, putty/paste type fuel tank sealer may do better. Much depends on the type of leak. Cracks are best stopped by drilling a tiny hole at the propegating (narrowest end) to stop it from continuing, then sealing it
