Re: Here We Go Again
Posted by Allan in NE on December 23, 2005 at 11:29:45 from (148.78.243.25):
In Reply to: Re: Here We Go Again posted by MNS on December 23, 2005 at 10:09:04:
MNS,
Just got back from the yard. Spent an hour nosin' and looking thru their carcuses and finally found enough stuff to make 'er work.
I've still got to use the 806 lift links,lower arms and the sway linkage but it will work. At least I found that silly drawbar swing plate affair. Has a weld but still serviceable.
Whew! What an ordeal! And that little gizmo must weight 100 lbs! Way heavier than the large chassis one.
Allan
third party image
