Re: Farmall A/B rear end question
Posted by Blake A on December 24, 2005 at 19:38:03 from (66.116.2.72):
In Reply to: Re: Farmall A/B rear end question posted by billde on December 24, 2005 at 19:13:37:
It does already have the cast wheel hub on the right side. I used it for mowing this year. I started restoring this winter and changed to an adjustable wide front. It looks to me like the A and B Axel tubes are different lengths causing seat mounting bracket problems, the B seat bracket on the right bolts to the top of the axel tube with a extra bracket, instead of up against the fender. Does anybody know how easy is it to change the axel tube? I assume I would need to change the differential shaft also due to shorter length of axel tube.
