Re: anybody ever try this?
Posted by CNKS on December 26, 2005 at 07:11:29 from (204.249.178.138):
In Reply to: anybody ever try this? posted by john koritansky on December 26, 2005 at 05:48:45:
You lost me, so if I don't understand what you are doing, ignore this post -- Super A hydraulics are no different from the C. If you don't have the factory remote, you need the block that fits between the reservoir and the lines to the pump. (Saginaw County Tractor and others). Run the new lines to a spool valve, then to the implement. Put a quick disconnect on the lines at the rear of the tractor. This will not interfere with normal touch control/rockshaft operation. The Super A/C is set up for two way cylinders. I suppose you could set it up for one way by eliminating the return line and venting the "down" port of the 2-way cylinder. If you have the factory remote (neater installation) I don't see the problem.
