986 running problem
Posted by Eldo case on December 27, 2005 at 04:54:14 from (72.161.244.57):
986 will start cold then run a little bit then die and won't start until it has a little starting fluid. The owner said it seemed better with the block heater warm. It will run ok unless you lug it and it dies or you idle it down fast it will die. Then it won't start unless you use starting fluid or it sets for ten minutes or so. Is it the pump? Thanks!
