Re: Farmall H info help
Posted by riverbend on December 27, 2005 at 05:18:32 from (208.160.33.168):
In Reply to: Farmall H info help posted by JBF on December 26, 2005 at 20:57:01:
Without looking, the X1 suffix indicates that your tractor came set up for gasoline. That's good, they have the higher compression heads. The casting number is in the middle of the head under the valve cover. I believe that number should be 8043.
Any domed pistons will increase the compression and power. Most kits come with over sized sleeves and pistons too.
Consider having the cam reground to Super H specs. (~0.030" more lift).
