Re: Changing from 6 to 12 volt
Posted by John T on December 27, 2005 at 08:22:12 from (66.244.90.98):
In Reply to: Changing from 6 to 12 volt posted by Glen525 on December 27, 2005 at 07:21:05:
Glen, I havent critically read all those articles but know BobM has some darn good n well detailed schematics for IHC you could also follow. The main generic things you need are usually a conversion to Negative gorund if youre not already there,,,,,,,,,swap any coil leads on coil ignition systems to match the ground,,,,,,,,,reverse the ammeter leads if grounds are reversed so it will read correctly,,,,,upgrade the main charging system wiring to 10 gauge if you use like a 50 amp Alternator, thats the wiring from the alternators main output to the ammeter and from the ammeter to the battery or starter wherever it gets its hot battery feed,,,,,,,,,,change any lights bulbs to 12 volt,,,,,,,,,,,,if its a coil ignition EITHER add a voltage dropping (12 to 6) in line series ignition Ballast Resistor after the ignition switch and ahead of the old 6 volt coil, or use a new full 12 volt rated coil,,,,,,,if its a GM 10SI Alternator, it will require switched excitation voltage to its lil No.1 side terminal for it to charge, take a look at Bobs Wiring Diagrams or the articles you mentioned and I recommend a 10 ohm current limiting protection resistor in the circuit if nones there via an idiot type light etc. John T
Home
| Forums
Today's Featured Article -
The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
