IH 414 Tractor
Posted by JimInOz on December 27, 2005 at 12:00:03 from (211.29.225.248):
I just bought an IH 414 tractor with diesel engine ,plus it has hyd pump running off engine,which goes to a lever/valve set up & on to 2 rear cylinders.Tractor runs well,but I can't get linkage hydraulics to raise up.
Oil was low when I purchased,so I filled it...but linkage still won't raise.
I have very little experience with ag tractor hydraulics....any advice/opinions appreciated.
Thanks.
