Re: Belt pulley case removal
Posted by captaink on December 27, 2005 at 12:41:20 from (66.115.214.56):
In Reply to: Re: Belt pulley case removal posted by captaink on December 27, 2005 at 12:39:43:
I should have added that you should check the end of the shift lever to see how tight it is in the rails. Chances are that it is worn, if so it can be built up with a welder.
