Re: Belt pulley case removal
Posted by kfox on December 27, 2005 at 21:07:37 from (63.18.249.156):
In Reply to: Re: Belt pulley case removal posted by captaink on December 27, 2005 at 12:41:20:
If the transmission had a lot of water in it, when you changed the oil, and the belt pulley hadn't been in gear for a long time you probably have some rusted bearings in the pulley gearbox. Had the same problem with my old H. I think the transmission gears sling the water up into the pulley gearbox, and some of it can't drain back. ken
