Re: Belt pulley case removal
Posted by RustyFarmall on December 27, 2005 at 14:08:53 from (216.248.75.150):
In Reply to: Belt pulley case removal posted by Randy-IA on December 27, 2005 at 12:21:29:
Randy, no such thing as a quick look on the belt pulley housing, even if you get it up you will need a new gasket to put it all back together. Best wait for a nicer day. Have you tried engaging the gearbox while the engine is running, and easing up on the clutch pedal until you feel movement in the handle? The pulley gearbox is just like the gears in the transmission, sometimes you have to grind them just a bit to get them fully engaged. Once you understand how to do that, it can be accomplished without grinding.
