Belt pulley case removal
Posted by Randy-IA on December 27, 2005 at 12:21:29 from (207.177.83.139):
Hi , I know it look's simple . Is it ? Or does the gas tank need to be lifted up some to help clear the fuel strainer ? This is an M tractor . The problem is it won't shift into gear . It turn's easy so either the poppet is stuck or the gear may be rusted to the shaft or ??? . The control arm seem's to move freely at least a little bit . This is with the tractor running or not . So I'm going to lift it off and take a look if I don't have to remove the gas tank that is . It's wet out and no place undercover to work on it so it's got to be a quick look . Thanks ...Randy
