Re: Farmall H Starting Problems.....
Posted by TomHath on December 27, 2005 at 14:11:28 from (206.99.145.229):
In Reply to: Farmall H Starting Problems..... posted by Farmall H PA on December 27, 2005 at 14:02:03:
It will flood if you choke it for more than one or two times around when cranking.
Pull the choke, hit the starter for just a second, then stop. Close the choke most of the way and hit the starter for real. If it still doesn't fire you probably don't have a good spark; first thing to do is clean and gap the points.
