Re: Farmall H Starting Problems.....
Posted by Turtle H on December 27, 2005 at 14:54:47 from (69.179.24.35):
In Reply to: Farmall H Starting Problems..... posted by Farmall H PA on December 27, 2005 at 14:02:03:
Install new points, condenser, rotor,cap, and spark plugs. Check the coil. Adjust carb idle mixture screw(1 to 1 1/2 turns open) and main fuel adjusting screw(2 1/2 to 3 turns open).When you try to start the tractor, USE CHOKE SPARINGLY.
This is the procedure I have always followed when I am trying to start a tractor that has been sitting for a few years or when a tractor is flooding when trying to start them
