Re: Losing Hydraulic fluid in Super C
Posted by Reddog on December 27, 2005 at 15:56:04 from (206.114.53.114):
In Reply to: Losing Hydraulic fluid in Super C posted by George Wallace on December 27, 2005 at 15:19:33:
Yes the hydralic oil is leaking into the oil pan. You will need to take off the hydralic pump, the fluid is leaking past the pump shaft into the oil pan. Your pump most likely has a seal or a O ring that seals around the shaft that must be bad. If the shaft has a groove worn into it you will need to put a speedy sleeve on the shaft. Hope this helps, Reddog
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
