Re: Rear wheel seal on 350
Posted by 350 HU Don on December 28, 2005 at 05:47:27 from (66.168.4.250):
In Reply to: Re: Rear wheel seal on 350 posted by Allan in NE on December 28, 2005 at 04:02:48:
No problem handling the wheel and tire assembly. I've had that off this tractor a couple of times and grew up on H's and 300's and like you, we moved the wheels for different purposes so I've had plenty of experience with wheels. I'm just concerned about whether I can reach the seal from the outside. I sure do appreciate all the good advice you guys give.
