Re: Farmall md Block
Posted by Andy Martin on December 28, 2005 at 10:19:32 from (64.219.39.195):
In Reply to: Farmall md Block posted by Mark in or on December 28, 2005 at 09:57:22:
I don't understand getting away from the dry sleeves. The diesel is high compression, and trying to raise it may cause other mechanical problems. On top of that, you are ruining an item through wear which is no longer being manufactured, whereas it can be resleeved many times.
