Farmall md Block
Posted by Mark in or on December 28, 2005 at 09:57:22 from (64.42.36.223):
How far can you Bore out a Farmall MD block before getting to thin on the water jackets. The bore of the block is 4.125 now. I want to make the cylinder in the block to a bore 4.25, 4.375 or how big can i go. I want to get away from using the dry sleeve but still doing some farm work with it. Is this a wrong idea from getting away from the dry sleeve or what??
