Re: Light refector's
Posted by john d on December 28, 2005 at 11:43:41 from (69.128.202.89):
In Reply to: Light refector's posted by Randy-IA on December 27, 2005 at 22:00:52:
I had no luck with the impact wrench. The bolt spun. I ended up using a nut splitter and separating the nut into three pieces. Had to do that on both lights.
I'm saving the old lights for a day when I have less to do. I'll try to re-hab them then. I installed teardrop-shaped halogen lights for now. They don't look right because they're chrome, but they are close to the same size and shape as the originals. I'll paint 'em red on a warmer day!
