Re: Farmall md Block
Posted by mark in or on December 28, 2005 at 12:19:13 from (64.42.36.223):
In Reply to: Farmall md Block posted by Mark in or on December 28, 2005 at 09:57:22:
I have three bad cylinders that are egg shaped. When i tore this motor down two of the sleeve had cracks around the top and one was in pieces in the bottom of the oil pan. so i have to bore some to get my block back in a usable state. So I'm safe to bore it to 4.25 using a sleeve or not?
