Re: Super A won't start - HELP!!!!!!
Posted by Mark in TN on December 30, 2005 at 12:51:07 from (68.114.166.197):
In Reply to: Super A won't start - HELP!!!!!! posted by Mark in TN on December 30, 2005 at 11:11:52:
I've checked the timing and the rotor points to No.1 at TDC on the compression stroke. The motor has not back fired at all and it didn't back fire when the rag caught on fire. Thanks old and El Toro.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
