Super A won't start - HELP!!!!!!
Posted by Mark in TN on December 30, 2005 at 11:11:52 from (68.114.166.197):
I've been restoring my 1952 Super A for well over two years now and finally got to the point where I was going to start it for the first time. I checked the distributor ignition and timed it to the engine and everything checked out. When I tried to start the motor it almost fired up but acted like it wasn't getting fuel. I pulled the plugs and they were dry. The funny thing is that the Zenith carburetor is dripping gas from the bottom of the wick. I pulled the carb and blew out all the jets and they are clear. I've lowered the float a couple times, but no change -- the carb still leaks and the tractor won't fire. I checked the viton needle seat and it seems to be working. I even persuaded my uncle to put some gas on a rag and hold it near the manifold port (carb off) while I turned the motor over by the hand crank -- the rag caught on fire! Scared both of us to death!! I don't understand my problem since the only adjustment on the carb is the idle. I had the carb working great prior to the rebuild. Anyone have any ideas or what I should try next? THANKS in advance for any help!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
