Re: Super A won't start - HELP!!!!!!
Posted by El Toro on December 31, 2005 at 14:18:06 from (64.12.117.13):
In Reply to: Re: Super A won't start - HELP!!!!!! posted by Mark in TN on December 31, 2005 at 12:45:32:
Don't feel bad about not being in time. That's very easy to do. to install the distr or mag 180 out. If you ever need to pull the distributor
make sure you know where the rotor is pointing and write it down. Then don't move the the engine until until you reinstall the distr. Makes you feel good when it starts. Enjoy your New Years now. Hal
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
