Re: Super A won't start - HELP!!!!!!
Posted by Mark in TN on December 31, 2005 at 12:45:32 from (68.114.166.197):
In Reply to: Re: Super A won't start - HELP!!!!!! posted by El Toro on December 31, 2005 at 06:12:24:
El Toro you were RIGHT!!! I'm ashamed to admit it, but it was 180 off and she fired right up! Since I didn't have anyone to help me this morning I put a compression tester on No.1 spark plug hole and turned the motor until the gauge moved and then lined the mark on the flywheel up with clutch housing. I couldn't believe my eyes when I popped the distributor cap off and saw the rotor pointing at No.4! I still can't believe I did that. Thanks to you and everyone who replied the Super A is running again!!! It will only run at full choke and dies when choke is off, plus I've got a bad oil leak at the oil filter case. The bolt bottoms out before it can put pressure on the case housing. When I bought the tractor it had 3 big washers at the top but still leaked at the top. I put the seal in at the bottom of the filter housing and a couple o rings at the top of the bolt but leaks bad when tractor is running. I only let it run about 5 seconds. It's cloudy and about 45 here in TN. I wished we would get some snow because we have not had a one to speak of in about 3 years. Thanks again to everyone who replied.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
