Re: oil pressure
Posted by old on December 31, 2005 at 16:12:06 from (207.69.136.200):
In Reply to: oil pressure posted by cub owner on December 31, 2005 at 15:46:28:
Remove the gauge/line which even it has and turn it over. If you get a good flow of oil its probably a bad gauge, but I still wouldn't run it till you replaced the gauge just so your sure.
