Re: Farmall 340
Posted by El Toro on January 01, 2006 at 06:56:18 from (64.12.117.13):
In Reply to: Farmall 340 posted by wayne L on January 01, 2006 at 06:28:19:
You need to pull the coil wire from the distr. cap and hold it within 1/4" of a good ground. Then have someone to attempt an engine start while you hold that coil wire. You may want to use a pair of insulated pliers. This should be a very hot spark. Is this a 12 volt ignition system with a ballast resistor between the ignition switch and the coil? For the fuel problem I would hold a hand over the carburetor throat and see if there's any suction. You need a good manifold vacuum to pull that atomized fuel into the engine. Was the engine rebuilt? A good fit with the rings and cylinders is what creates this vacuum. When you had No1 piston at TDC on the compression stroke were both valves closed? Hal
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
