Farmall 340
Posted by wayne L on January 01, 2006 at 06:28:19 from (4.158.156.155):
A quick update on my 340. I redid the heads and got some help from you folk regarding it not starting. Thanks for the advise but I still have no go. I set the valve guides to .018 intake and .022 exhaust which was per a dealer. I also gave each cylinder a squirt of oil to help with suction and now It does not fire at all. I check the distributor and when cylinder #1 is at TDC on the compresson stroke the rotor it at #1. I am still puzzled why the plugs are dry and not drawing gas. I took off the carb and cleaned and replaced the needle/seat and jets. Everything seems to be working?. When I choke it there is gas running out the bottom of the carb and the choke is opening and closing when I choke it. Back to the distributor. I pulled of the rotor and checked the points. I have spark when I manually opened and closed the points. Not alot but it is sparking?. Can anyone provide more help?.
Thanks
Wayne
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
