Re: allen in ne possible wf headache cure
Posted by Janicholson on January 01, 2006 at 13:09:22 from (66.173.50.138):
In Reply to: Re: allen in ne possible wf headache cure posted by Allan in NE on January 01, 2006 at 07:43:37:
Allen, From remembering the earlier pics, I have one question and if yes then maybe a solution (or partial one). Are the spindle shafts turning against stops, and or do they have stops? If they aren't, or there are no stops, I would try this. Make a plate 3"X4-1/2"X 3/4" thick. Drill two holes in the plate that match the spacing of the inner tie rods mounting studs from each other. Drill two tapered holes about 3" away that fit the taper of the studs. Place this plate on the under side of the steering arm and bolt in place with grade 8 bolts. This will provide substantially more travel to the tierods. Note distances and sizes are guesses on mu part. We did this on a cobbled together H with a truck axle to make it turn better. The correct approximate geometry of an axle with the radius arms on the rear side of the spindle, has the radius arms pointing to the center of the rear axle when the tires are straight ahead. This causes the inner wheel to turn more than the outer, on a sharp corner. I hope I helped some, JimN
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
