Re: allen in ne possible wf headache cure
Posted by scotc on January 01, 2006 at 21:04:51 from (65.220.16.62):
In Reply to: Re: allen in ne possible wf headache cure posted by Janicholson on January 01, 2006 at 13:09:22:
I think they are pointing in more than they need to be. If it is hitting the stops(which is how i understand it?) then lengthening tie rods and spinning the arms out on the spindle would probably be the cheapest most effective route. I'd say you have parts that will work together if set up properly. Also working in dry climates I personally would want a minimal amount of ackerman (inside wheelcut tighter than outer) built into the steering because even low speed turns could scuff the inside tire's track. But I can't say i've ever seen the inside tire on a high-ackerman setup track true and the outer scuff without using the brakes to turn so I have to question if it even helps turn the tractor, or if having both tires tracking closer to parallel would be better because they would both be planted instead of one scuffing already. But then again, it may help when using the brake to help turn.
Anyhow, stop blocks in the way, I'd go my way, stop blocks not in the way, I'd try Janicholson's. Or throw both at it and maybe that inside rear wheel will spin backwards, who knows?
May be a while before I'm back again, so don't be too harsh on my ideas, ok?
