Re: What block do I have?
Posted by JakeF on January 01, 2006 at 13:12:30 from (64.146.188.222):
In Reply to: What block do I have? posted by DelMN on January 01, 2006 at 10:47:05:
If it was from a baler or power unit it will probably have the starter cutout on the RH side of the block and you will have a halfcircle hole in your bellhousing. It'll work but you will have one less bellhousing bolt ond you should make a plug to keep stuff out of the bellhousing. Jake
