Re: Farmall Cub Voltage Regulator (Cut-out) wiring
Posted by Bob on January 01, 2006 at 15:08:43 from (64.21.249.40):
In Reply to: Re: Farmall Cub Voltage Regulator (Cut-out) wiring posted by Bob on January 01, 2006 at 15:04:23:
Nope, didn't work forme, either! You'll have to do it the hard way!
I am going to post this over on Tractor Talk, to see if the link will "take" there.
