Re: Farmall 340
Posted by potosi on January 01, 2006 at 17:35:14 from (72.161.238.113):
In Reply to: Farmall 340 posted by wayne L on January 01, 2006 at 06:28:19:
I recently did a valve job on my 340.In the process I replaced the points and condenser.I had problem starting.Turned out to be the points.The contact on the bracket that is held with a screw was loose.I replaced and it startes every time now.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
