Re: 123cu swap to 135?
Posted by Jeff311 on January 01, 2006 at 19:46:00 from (71.98.75.142):
In Reply to: 123cu swap to 135? posted by fredmich on January 01, 2006 at 07:56:14:
340 block (135 cu in) is different bolt pattern and block configuration than the 240 (123 cu in). You can use the 404 block (135 cu in) as it is the same bell housing bolt pattern as the 240. Although the 340 and 404 both had 135 Cu in engines, they had different blocks and will not interchange.
